*meshline_create_from_plot_elements
Creates meshlines from selected plot elements.
*meshline_create_from_plot_elements mark_id reserved1 reserved2 reserved3 reserved4 reserved5 reserved6
HyperMesh Tcl Modify Command
This command creates meshlines from selected plot elements.
- mark_id
- The ID of the mark containing the plot elements. Valid values are 1 and 2.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
- reserved3
- reserved4
- reserved5
- reserved6
To create meshlines from all displayed plot elements:
*createmark elems 1 displayed
*meshline_create_from_plot_elements 1 0 0 0 0 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
