*midsurface_update_from_plate_edit
Removes relevant pre-existing midsurfaces and plate display components, extracts mid-surfaces corresponding to the existing plate edit information, and re-draws the plate display components.
*midsurface_update_from_plate_edit entity_type mark_id outbound_normals thickness_bound align_steps extract_by_comp rerun_type stitch_tol_mode max_R_t_ratio reserved_1 reserved_2 max_thickness_ratio min_thickness max_thickness mid_position reserved_3 reserved_4 reserved_5 new_or_curr_comp
HyperMesh Tcl Modify Command
The command removes relevant pre-existing midsurfaces and plate display components, extracts mid-surfaces corresponding to the existing plate edit information, and re-draws the plate display components. This command replicates and expands upon the functionality available in the *midsurface_extract_10 command, and all parameters have the same meaning as for *midsurface_extract_10.
- entity_type
- The type of entity selected for mid-surface extraction. Valid values are surfaces and solids.
- mark_id
- The ID of the mark containing the input entities.
- outbound_normals
- If entity_type is surfaces:
- -1 - If surfaces selected on mark_id form a closed solid (but entity_type parameter is not set to solid). In this case the surfaces will be re-oriented, if needed, to have the normals go outside the solid they form.
- 0 - If the normals go inside the selected surfaces
- 1 - If the normals go outside the selected surfaces
- thickness_bound
- Limits on midsurface thickness:
- align_steps
- Determines how steps are aligned for solids with discrete sections. This parameter
also determines whether any specified base surfaces are taken into account when
constructing the middle surface. If the values are 0, 1, or 2, the base surfaces are not
used. In order to take the base surfaces into account, the value should be increased by 3.
- 0 - Steps are not aligned at the thickness jumps (jumps maintained). Base surfaces will not be used.
- 1 - Steps aligned at the thickness jumps. Mid-surface position set automatically. Base surfaces will not be used.
- 2 - Steps aligned at the thickness jumps. Mid-surface position set using mid_position. Base surfaces will not be used.
- 3 - Steps are not aligned at the thickness jumps (jumps maintained). Base surfaces specified by you will be taken into account.
- 4 - Steps aligned at the thickness jumps. Mid-surface position set automatically. Base surfaces specified by you will be taken into account.
- 5 - Steps aligned at the thickness jumps. Mid-surface position set using mid_position. Base surfaces specified by you will be taken into account.
- extract_by_comp
- 0 - Extraction of the mid-surfaces can occur between any matching pair of the surfaces.
- 1 - Extraction of the mid-surfaces can occur only between the surfaces that belong to the same component.
- rerun_type
- Used to specify one of the midsurface extraction methods: offset, offset+planes and
offset+planes+sweeps. If the value is 0, 1, or 2 the extraction method is "offset". If
you want to use extraction method "offset+planes" instead, the value should be increased
by 3. If you want to use the extraction method "offset+planes+sweeps", the value should
be increased by 6.
- 0 - Simply extracts the mid-surface. Midsurface extraction method is "offset".
- 1 - Extracts the mid-surface and at the same time copies the lines that collapsed into "Collapsed Lines" component. Midsurface extraction method is "offset".
- 2 - Extracts the mid-surface by collapsing only the lines that are in the "Collapsed Lines" and "Just added Collapsed Lines" components. Additionally, it moves lines from "Just added Collapsed Lines" component into "Collapsed Lines" component. Midsurface extraction method is "offset".
- 3 - Simply extracts the mid-surface. Midsurface extraction method is "offset+planes".
- 4 - Extracts the mid-surface and at the same time copies the lines that collapsed into "Collapsed Lines" component. Midsurface extraction method is "offset+planes".
- 5 - Extracts the mid-surface by collapsing only the lines that are in the "Collapsed Lines" and "Just added Collapsed Lines" components. Additionally, it moves lines from "Just added Collapsed Lines" component into "Collapsed Lines" component. Midsurface extraction method is "offset+planes".
- 9 - Simply extracts the mid-surface. Midsurface extraction method is "offset+planes+sweeps".
- 10 - Extracts the mid-surface and at the same time copies the lines that collapsed into "Collapsed Lines" component. Midsurface extraction method is "offset+planes+sweeps".
- 11 - Extracts the mid-surface by collapsing only the lines that are in the "Collapsed Lines" and "Just added Collapsed Lines" components. Additionally, it moves lines from "Just added Collapsed Lines" component into "Collapsed Lines" component. Midsurface extraction method is "offset+planes+sweeps".
- stitch_tol_mode
- Defines the mode for performing mid-surface stitching. Valid values are:
- 0 - Final stitching of the mid-surfaces is performed using a local tolerance of 1/5 of the local surface thickness (default in prior versions).
- 1 - Final stitching of the mid-surfaces is performed using the geometry cleanup tolerance. This is recommended when extensive manual editing of the auto mid-surfacing result is expected, because having "far" stitching may misrepresent the geometry of the model and affect subsequent geometry operations.
- max_R_t_ratio
- This is a ratio between the fillet radius and plate thickness analyzed at T, X and similar junctions. If the calculated ratio is greater than this parameter, the fillet does not collapse. In previous releases the ratio was a default value of 2 and could not be changed
- reserved_1
- Reserved for future use. Must be set to 0.
- reserved_2
- max_thickness_ratio
- This is a ratio between a plate thickness found during the midsurfacing and the minimum plate thickness found during the midsurfacing. If the ratio is exceeded the corresponding midsurface will be ignored. The parameter is used when thickness_bound is 0. It can be any real number > 1.
- min_thickness
- Sets the minimum plate thickness bound. This parameter is used when thickness_bound is 1. It can be any real number ≥ 0.
- max_thickness
- Sets the maximum plate thickness bound. This parameter is used when thickness_bound is 1. It can be any real number > min_thickness.
- mid_position
- Sets the midsurface position for step alignment case when align_steps is set to 2. This can be any number between 0 and 1.
- reserved_3
- Reserved for future development. Value = undefined.
- reserved_4
- reserved_5
- new_or_curr_comp
- 0 - Midsurface will be created in the current component.
- 1 - Midsurface will be created in a new component named "Middle Surface".
To extract the midsurface of solids ID 5 through 7, no thickness bounds, align the steps at 0.39, only extract surfaces between the same component, max thickness ratio of 10, and organize them into the "Middle Surface" component:
*createmark solids 1 5 6 7
*midsurface_update_from_plate_edit solids 1 3 0 2 1 0 0 2 10 0 0 0.39 undefined 0 0 1
# Handle error
}Version History
13.0
