*undohistorystate
Undoes one or more history states.
*undohistorystate count
HyperMesh Tcl Modify Command
- count
- The number of history states to undo.
To undo two history states:
*undohistorystate 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
