*animationframeprevious
Returns to the previous animation frame.
HyperMesh Tcl Modify Command
This command returns to the previous animation frame.
Examples
To return the animation to the previous
frame:
*animationframepreviousErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
