*CE_FE_CreateUCCFromDCC
Creates a connector control from a connector control default.
*CE_FE_CreateUCCFromDCC cc_name ccd_name
HyperMesh Tcl Modify Command
- cc_name
- The name of the connector control to create.
- ccd_name
- The name of the connector control default to use.
Examples
Create a connector control named "my_acm" from the connector control default "acm_(general)_spot_nastran_template":
*CE_FE_CreateUCCFromDCC "my_acm" "acm_(general)_spot_nastran_template"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
