*solid_cavity_detect_local
Extracts cavity surfaces based on input rims and a face of that cavity.
*solid_cavity_detect_local mark_id face_id fill_flag
HyperMesh Tcl Modify Command
This command must be followed by a call to *solid_cavity_detect_end.
- mark_id
- The ID of the mark containing the surface edges defining the rims of the cavity.
- face_id
- The ID of a surface within the cavity.
- fill_flag
- 0 - Creates a region entity.
Examples
Extracts the cavity and creates a solid representing that cavity, with IDs of rim edges 1724, 210, 961 and 333, and face ID 73:
*createmark lines 1 1724 210 961 333
*solid_cavity_detect_local 1 73 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
