*exportuserdefinedshapes
Exports shape design variables, shapes and nodal information in user-defined format for HyperStudy or Templex analysis codes.
*exportuserdefinedshapes header keyword delimiter1 delimiter1_value nodeid_width delimiter2 delimiter2_value x_coord_width x_coord_precision y_coord_width y_coord_precision z_coord_width z_coord_precision delimiter3 delimiter3_value outputfile
HyperMesh Tcl Modify Command
This command exports shape design variables, shapes and nodal information in user-defined format for HyperStudy or Templex analysis codes.
- header
- Header information for the node block.
- keyword
- Keyword for a node.
- delimiter1
- The delimiter type between keyword and the node ID. Valid values are:
- Delimiter - Use for delimiters such as slash, comma, etc.
- Whitespace - Use for spaces.
- delimeter1_value
- If deliminter1 is Delimiter, this is the character to use as the delimiter.
- nodeid_width
- Width of the node ID field.
- delimiter2
- The delimiter type between the node ID and the x-coordinate. Valid values are:
- delimeter2_value
- If deliminter2 is Delimiter, this is the character to use as the delimiter.
- x_coord_width
- Field width for output of the x-coordinate.
- x_coord_precision
- Field precision for output of the x-coordinate.
- y_coord_width
- Field width for output of the y-coordinate.
- y_coord_precision
- Field precision for output of the y-coordinate.
- z_coord_width
- Field width for output of the z-coordinate.
- z_coord_precision
- Field precision for output of the z-coordinate.
- delimiter3
- The delimiter type between the x-y and y-z coordinates. Valid values are:
- delimeter3_value
- If deliminter3 is Delimiter, this is the character to use as the delimiter.
- outputfile
- Name of the output file.
To output nodal coordinates in the following format to the shape.dat
file:
COORDINATES
NODE / 8844, 5.0000000e+001 6.0000000e+001 5.0000000e+001
*exportuserdefinedshapes "COORDINATES" "NODE " "Delimiter" "/" 9 "Delimiter" "," 15 7 15 7 15 7 "Whitespace" 1 "shape.dat"Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
