*removemodel
Removes a secondary model.
*removemodel name ?make_current?
HyperMesh Tcl Modify Command
- name
- The name of the secondary model to remove.
- make_current
- The optional name of the model to make current if the current model is removed. If not specified, the primary model is made current (default).
Examples
To remove the secondary model named model-2:
*removemodel model-2To remove the secondary model named model-2 and make model-3 as
current:
*removemodel model-2 model-3Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
2020 - Added new option make_current.
