*modelcheck_createchecks
Loads a model check config file and creates check and correction entities.
*modelcheck_createchecks filename ?add?
HyperMesh Tcl Modify Command
- filename
- The full path and file name of the config file to load.
- add
- 0 - Only the checks in the new config file will be loaded (default)
Examples
To load the config file
C:/temp/my_checks.xml:
*modelcheck_createchecks "C:/temp/my_checks.xml"To append the config file
*modelcheck_createchecks "C:/temp/my_checks.xml" 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
