*addnewmodel
Used by multiple models to add a new secondary model.
*addnewmodel name ?read_only?
HyperMesh Tcl Modify Command
Used by multiple models to add a new secondary model. A new file can be loaded in this newly created secondary database.
- name
- The unique name of the new model to add.
- read_only
- Optional argument that says whether the new model is read only (1) or editable (0, default).
Examples
To add a new secondary model named model-2:
*addnewmodel model-2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
2020.1 - Added new optional argument read_only.
