*meshspinelements2
Creates solid elements by spinning 2D elements around a plane normal.
*meshspinelements2 mark_id plane_id angle on_spin bias_style biasing organize
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the elements to be dragged.
- plane_id
- The ID of the plane normal about which the elements should be spun, created using *createplane.
- angle
- The angle which the elements should be spun.
- on_spin
- The number of elements to create along the spin.
- bias_style
- The style of biasing to use.
- biasing
- The biasing intensity value.
- organize
- 0 - Elements to original component
To create 5 elements by spinning elements 10 and 11 about the plane normal defined by (0.0, 0.0, 1.0) and based at (20.0, 20.0, 0.0) by an angle of 90.0, and have the resulting elems in the original comp:
*createplane 0.0 0.0 1.0 20.0 20.0 0.0
*createmark elements 1 10 11
*meshspinelements2 1 1 90.0 5 1 0.0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
