*movemarkgroup
Organizes main/secondary elements into groups.
*movemarkgroup entity_type mark_id name
HyperMesh Tcl Modify Command
Moves main/secondary elements from one group to another.
- entity_type
- Must be set to elems.
- mark_id
- The ID of the mark containing the main/secondary elements to move. Valid values are 1 and 2.
- name
- The name of the group to move the entities to.
To move all elements from group1 to group2: to :
*createmark elems 1 "by group name" group1
*movemarkgroup elems 1 group2
Incorrect usage results in a Tcl error. To detect errors, you can use the catch
command:
if { [ catch {*movemarkgroup...} ] } {
# Handle error
}Version History
10.0
