*convertinclude
Converts a regular include file into an include transform include file or vice versa.
*convertinclude id shortname flag
HyperMesh Tcl Modify Command
- id
- The include ID, or 0 to use shortname.
- shortname
- The short name of the include file. This can be empty if id is specified other than 0.
- flag
- 1 - Convert a regular include into an include transform include
To convert regular include file with ID 10 into an include transform include file:
*convertinclude 10 "" 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019.1
