*CE_MarkCombineLinks
Combine the individual/group links into a single group link.
*CE_MarkCombineLinks mark_id search_type search_rule update_state search_string_array search_number_of_strings ?keep_realized?
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark of connectors to combine. Valid values are 1 and 2.
- search_type
- The specific link type to search in the connector.
- search_rule
- The rule by which the link entity was added to the connector:
- update_state
- The update state of the links desired to be grouped:
- search_string_array
- A string array containing the list of of link IDs/names/UIDs need to be combined into a group, created using*createstringarray. This must be set to 1.
- search_number_of_strings
- Integer indicating the size (number of strings) in the search_string_array created using *createstringarray.
- keep_realized
- Option to keep the current connector state after the update operation:
Examples
To combine the component link IDs 1,2,3 and 4 of the connector IDs 2 and 5 into a group link:
*createmark connectors 1 2 5
*createstringarray 4 1 2 3 4
*CE_MarkCombineLinks 1 comps 1 2 4 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
