*maskentitiesincollector
Masks the specified entities contained within the specified collectors.
*maskentitiesincollector entity_type mark_id flag_1 flag_2 flag_3 flag_4 flag_5 flag_6
HyperMesh Tcl Modify Command
This command masks the entities contained within the collectors of entity_type that are on mark_id. Valid mark_ids are 1 and 2. Only entities in displayed collectors may be masked.
The six flag arguments indicate the type of entities to mask within the specified collectors. If the flag is set to 1, that entity is masked. If the flag is set to 0, that entity is not modified. See the list below for the currently supported entity_types and flags.
- comps
- flag_1: elements
- groups
- flag_1: main elements
- loadcols
- flag_1: loads
To mask all of the points and surfaces in the displayed components:
*createmark components 1 displayed
*maskentitiesincollector comps 1 0 1 0 1 0 0
# Handle error
}Version History
9.0
