*loadsupdatefixedvalue
Updates the fixed constraint value on SPC and SPCD constraint loads for OptiStruct.
*loadsupdatefixedvalue mark_id fixed_value
HyperMesh Tcl Modify Command
Updates the fixed constraint value on SPC and SPCD constraint loads forOptiStruct.
- mark_id
- The ID of the mark containing the SPC and SPCD constraints to update. Valid values are 1 and 2.
- fixed_value
- 0 - Do not retain the deformed boundary resulting from a preceding nonlinear subcase
To update a fixed value for SPC load 4:
*createmark loads 1 4
*loadsupdatefixedvalue 1 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.120
