*realizemasselementstosolvermasses
Creates nodal group solvermasses out of mass elements.
*realizemasselementstosolvermasses mark_id
HyperMesh Tcl Modify Command
Currently used in solver conversion from OptiStruct/Nastran to LS-DYNA.
- mark_id
- The ID of the mark of mass elements to convert. Valid values are 1 and 2.
Examples
Convert all mass elements in the model:
hm_createmark elems 1 "by config type" "0 1 1"
* realizemasselementstosolvermasses 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
