*batchparams_write
Write the global mesh quality parameters to a file.
*batchparams_write filename
HyperMesh Tcl Modify Command
- filename
- The full name and path of the file to write.
Examples
To write the parmeters to C:/temp/5mm.param:
*batchparams_write C:/temp/5mm.param
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
