*midsurface_clear_plate_info
Deletes the plate and thickness information from selected surfaces.
*midsurface_clear_plate_info mark_id reserved1 reserved2
HyperMesh Tcl Modify Command
Deletes the plate and thickness information from selected surfaces, which was created via previous midsurface runs, or via plate edit commands.
- mark_id
- The ID of the mark containing the surfaces to clear. Valid values are 1 and 2.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
Examples
To delete the plate and thickness information from surfaces with ID 5-7:
*createmark surfs 1 5-7
* midsurface_clear_plate_info 1 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
