*segmentsetaddmixedfaces
Adds element faces to a segment set.
*segmentsetaddmixedfaces name elem_mark_id node_mark_id break_angle reverse_normals
HyperMesh Tcl Modify Command
- name
- The name of the segment set to update.
- elem_mark_id
- The ID of the mark containing the elements to add. Valid values are 1 and 2.
- node_mark_id
- The ID of the mark containing the nodes that define an edge or a face of an element. Valid values are 1 and 2.
- break_angle
- The break angle for finding adjacent elements.
- reverse_normals
- Create segment set:
Examples
To add elements 1-100 with faces defined by nodes 1-5 to the segment set "test" with a
break_angle of 30.0:
*createmark elems 1 1-100
*createmark nodes 1 1-5
*segmentsetaddmixedfaces "test" 1 1 30.0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
