*bm_markpreservedcompsboundary
Flags the boundaries of components to be preserved during batch meshing and autocleanup.
*bm_markpreservedcompsboundary mark_id common_bound free_edges
HyperMesh Tcl Modify Command
- mark_id
- 1 or 2 - The mark containing the desired components.
- common_bound
- 0 - Boundaries between components within the selection are flagged.
- free_edges
- 0 - Free edges are not marked for preservation.
Examples
Mark the boundaries of components 100 and 101, flagging only the boundary of the entire
selection:
*createmark comps "by id only" 100 101
*bm_markpreservedcompsboundary 1 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
