*maketempfrompreservednodes
Converts nodes from preserved nodes to temp nodes.
*maketempfrompreservednodes mark_id
HyperMesh Tcl Modify Command
This command converts nodes from preserved nodes to temp nodes.
- mark_id
- The ID of the mark containing the nodes to convert. Valid values are 1 and 2.
To convert nodes 1-4 from temp to preserved:
*createmark nodes 1-4
*maketempfrompreservednodes 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
