*renameviewmask
Renames a view saved using *saveviewmask.
*renameviewmask old_name new_name
HyperMesh Tcl Modify Command
- old_name
- The name of the view to rename. The numbers 1-5 are reserved and cannot be used.
- new_name
- The new name of the view. The numbers 1-5 are reserved and cannot be used.
To rename a view from "my_view" to "isometric":
*renameviewmask "my_view" "isometric"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
