*rebuild_mesh_advanced
Remesh/Improve selected shell elements with quality and flow considerations, and optional flow guide selections to guide the mesh directions.
*rebuild_mesh_advanced mark_id ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
- Surface hole recognition table
- Feature angle during element cleanup
- Element type
- Mesh type
1Ds attached to the input shell elements are used as features and they significantly impact the mesh quality and flow. If no 1Ds are present in the shells of the input elements, the specified feature angle is internally used to recognize features.
Rebuild/improve is currently supported for first-order shell elements that are not attached to solid elements.
- mark_id
- The ID of the mark of elements to rebuild or improve. Valid values are 1 and 2.
- flow_guides=<value>
- A set of lines that are used to guide the mesh directions. Each line is composed of a list of points, and it follows a format of "number_of_points p1_x p1_y p1_z p2_x p2_y p2_z ?p3_x? ?p3_y? ?p3_z? ... ?pN_x? ?pN_y? ?pN_z?".
- keep_selection=<value>
- Flag to keep the element selection for selective rerun. Valid values are:
- mode=<value>
- The mode of the operation. Valid values are:
- rebuild_connectors=<value>
- Flag to rebuild connectors. Valid values are true and false (default).
Examples
*createstringarray 14 " 0 penalty value 0.00 0.00 0.50 1.00 5.00" \
" 1 min length 1 2.0 5.000 4.333 3.666 3.000 2.833 2" \
" 2 max length 1 1.5 5.000 6.200 7.320 9.000 11.290 0" \
" 3 aspect ratio 1 1.0 1.000 2.000 4.000 5.000 10.000 0" \
" 4 warpage 1 2.0 0.000 5.000 15.000 20.000 40.000 0" \
" 5 max angle quad 1 1.0 90.000 110.000 140.000 150.000 165.000 0" \
" 6 min angle quad 1 1.0 90.000 70.000 40.000 30.000 15.000 0" \
" 7 max angle tria 1 1.0 60.000 80.000 120.000 130.000 155.000 0" \
" 8 min angle tria 1 1.0 60.000 50.000 30.000 20.000 10.000 0" \
" 9 skew 1 1.5 0.000 10.000 50.000 60.000 75.000 0" \
" 10 jacobian 1 2.0 1.000 0.900 0.600 0.500 0.350 0" \
" 11 chordal dev 0 0.0 0.000 0.300 0.800 1.000 2.000 0" \
" 12 taper 0 1.0 0.000 0.200 0.500 0.600 0.900 0" \
" 13 % of trias 1 2.0 0.000 3.000 4.500 6.000 9.000 0"
*setqualitycriteria 1 14 0
*createstringarray 105 "geometry_cleanup_flag 1" "meshing_flag 5" \
"element_size 5.0" "element_type 2" \
"mesh_align 3" "element_order 1" \
"surf_component 1" "feature_angle 30.0" \
"holes_table_begin" "appl_surf(1)" "appl_solid(0)" "appl_cordsfiles(0)" "appl_flanged_suppr(1)" \
"flanged_suppr_height(1.4)" "narrow_slots_type(0)" "abs_fixed_nodes_count_max(-8)" \
"rad(0.0,2.2) do action(1) washer(0) " "rad(2.2,3.01) do action(0) elems(4) washer(0) " \
"rad(3.01,4.7) do action(0) elems(6) washer(1) layers(3.5) " "rad(4.7,9.0) do action(0) elems(8) washer(1) layers(0.75*radius) " \
"rad(9.0,11.0) do action(0) elems(8) washer(1) layers(7.0) " "rad(11.0,20) do action(0) elems(8) washer(1) layers(auto) " \
"rad(0.0,2.2) solid(1) do action(1) " "rad(2.2,3.01) solid(1) do action(0) elems(4) " \
"rad(3.01,20) solid(1) do action(0) elems(6) " "holes_table_end" "edge_fillet_recognition 1" \
"max_fillet_radius 5.0" "surface_fillet_table_begin" "surface_fillet_recognition(1)" \
"minimize_transitions(1)" "rad(0,2.2) wid(3.0,6.2) do split(suppress_on)" \
"rad(2.2,15) wid(3.4,6.2) do elems(1)" "rad(0,25.0) wid(6.2,9.2) do elems(2)" \
"rad(0,35.0) wid(9.2,12.5) do elems(3)" "rad(0,40.0) wid(12.5,25.0) do chordal_deviation(0.2)" \
"surface_fillet_table_end" "del_dupl_surfs_flag 2" "del_dupl_surfs_tol -1" \
"edges_stitch_flags 0" "max_edges_stitch_tol -1.0" \
"fix_overlapsurfs_flag 1" "overlapsurfs_maxtangangle -1.0" \
"beads_suppression 1" "beads_recognition 1" \
"minimal_beads_height 1.4" "beads_treat_flags 0" \
"flange_recognition 1" "flange_elements_across 3" \
"flange_max_width 30.0" "flange_min_width 8.0" \
"flanges_treat_flags 1" "flange_max_remove_width -1.0" \
"appl_tria_reduction 1" "tria_redu_max_elemsize auto" \
"tria_redu_min_elemsize auto" "trias_around_holes 0" \
"common_mesh_flow 0" "extract_thinsolids 1" \
"midsurf_method 3" "thinsolid_ratio 0.3" \
"max_thickness 10.0" "extract_feature_angle 25.0" \
"pre_midsurf_cleanup 1" "direct_midmesh 0" \
"ignore_flat_edges 1" "flatten_connections 0" \
"defeat_open_width_on 1" "defeat_open_width 1.0" \
"supp_proxim_edges_on 1" "supp_proxim_edges 0.5" \
"combine_nonmanifold_on 1" "combine_nonmanifold 0.5" \
"midmesh_extact_elem_size 10.0" "remove_logo 1" \
"logo_max_size 30.0" "logo_max_height 1.4" \
"logo_min_concavity 1.0" "threads_removal 0" \
"threads_toremove_max_depth 5.0" "threads_replacediametertype -2" \
"folded_elems_angle 150.0" "smooth_elems_target 0.2" \
"fillets_mesh_flow 0" "failed_elems_cleanup_flgs 8" \
"move_nodes_across_feature_edges 1" "featureedge_nodes_moveacross_max 0.1" \
"move_nodes_across_free_edges 1" "freeedge_nodes_moveacross_max 0.05" \
"move_normal_flag 1" "move_normal_dist 0.8" \
"divide_warped_quads 1" "ignore_comps_boundary 0" \
"gen_topology_prepare_flags 7" "cleanup_comp_flag 0 " \
"comp_select " "use_wildcards_for_compsnames 0" \
"cleanup_tolerances auto" "suppress_features_rate 0" \
"feat_charsize_method 0" "custom_feat_suppr_maxangle 25.0" \
"uncond_constr_lines_suppress 0" "aggressive_fillet_lines_suppress 0"
*createbatchparamsfromstrings 1 105
*createmark elements 1 displayed
*rebuild_mesh_advanced 1 keep_selection=failed "flow_guides=2 308.746697 719.296657 906.673771 339.768568 714.811262 904.452529"Errors
# Handle error
}Version History
2020.1
2024 - Added new option rebuild_connectors.
