*setqualitythresholdscolors
Sets the color for all element quality index ranges.
*setqualitythresholdscolors double_array number_of_doubles
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the color for all element quality index ranges.
- double_array
- The ID of the double array containing the color values for each quality index range. Must always be set to 1.
- number_of_doubles
- Must currently be set to 5.
To assign the quality index thresholds colors: ideal 56 (green), good 41 (cyan), warn 28 (brown), fail 57 (yellow) and worst 3 (red):
*createdoublearray 5 56 41 28 57 3
*setqualitythresholdscolors 1 5
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
