*createcenternode
Creates a node at the center of a circle defined by 3 input nodes.
*createcenternode node_id1 node_id2 node_id3
HyperMesh Tcl Modify Command
- node_id1
- The ID of the first node defining the circle.
- node_id2
- The ID of the second node defining the circle.
- node_id3
- The ID of the third node defining the circle.
Examples
To create a node at the center of the circle defined by nodes 100, 200 and
300:
*createcenternode 100 200 300Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
