*metadatamarkbool
Creates bool metadata on the entities on the specified mark.
*metadatamarkbool entity_type mark_id name value
HyperMesh Tcl Modify Command
- entity_type
- The type of entities contained on the mark. The undef entity type is used to store metadata on the model itself.
- mark_id
- The ID of the mark containing the entities to which the metadata will be added. Valid values are 1 and 2.
- name
- The name by which the metadata will be referenced.
- value
- The Boolean value assigned to the metadata (0 or 1).
Examples
To add metadata named Bool_Val with the value 0 to elements ID
1-100:
*createmark elems 1 1-100
*metadatamarkbool elems 1 "Bool_Val" 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.2
