*modifyicelement
Modifies a dependent node of an IC element.
*modifyicelement id mode node_id
HyperMesh Tcl Modify Command
- id
- The ID of the IC element to modify.
- mode
- 1 - Move up in the order
- node_id
- The ID of the node to modify.
Create an IC element with independent node 15, and dependent nodes to 16, 17, 18, 19 with DOF’s 123, 345, 1234, 123456, then remove node 18:
*icelementcreate
*createintarray2d 2 4 16 17 18 19 123 345 1234 123456
*addicconnectivity 1 15 1 2 4
*modifyicelement 1 3 18
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
