*createentity
Create a new entity with specified data.
*createentity entity_type ?modelname=<name_of_model>? ?name1=value1? ?name2=value2? ... ?name3=valueN?
HyperMesh Tcl Modify Command
Create a new entity with specified data. Data names only are allowed to be set. If the data name “name” is specified when creating an entity enabled for the name pool, the command uses the provided name to define the solver name.
There are also a few limitations to this command:
- Attributes are not supported.
- STATUS is not supported.
- entity_type
- Entity type to create.
- <name>=<value>
- The name=value data name and/or attribute pairs that define the relevant data for the entity. For attributes, this can be either the attribute name or ID.
- modelname=<name_of_model>
- This is the optional model name to update when there are multiple models in the database. If not specified, the current model is used.
Examples
Create a set with a default set type and name.
*createentity setsCreate a set of type nodes and node IDs
1-4:
*createentity sets type=1 ids={1 2 3 4}Create a set with name set1, cardimage
GRNOD:
*createentity sets name=set1 cardimage=GRNODCreate a node with coordinates x = 100.0, y = 200.0, z =
0.0:
*createentity nodes x=100 y=200 z=0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
2020.1 - Added new option modelname.
