*linemarkremovepinholes
Removes 2D holes in the geometry, that has single boundary line, by filling it with surface. Optionally, one can create a vertex point at the center of the hole.
*linemarkremovepinholes mark_id exclude_point
HyperMesh Tcl Modify Command
Removes 2D holes in the geometry. The holes are supposed to have only one boundary line. The command removes these holes by filling it with surface. When possible, the new surface is created without any boundary, thus the surrounding surface just extends to fill the hole. Otherwise, the boundary of the new surface is suppressed so that it becomes a single surface together with its surrounding surface.
- mark_id
- The ID of the mark containing the input lines defining the hole perimeters. Valid values are 1 and 2.
- exclude_point
- 0 - Create a point at the center of the hole.
Examples
To remove the holes that are bounded by lines 20 and 21, creating a vertex point at their
center:
*createmark lines 2 20 21
*linemarkremovepinholes 2 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
