*solid_cavity_detect_modify_surfaces
Modify a partially detected cavity by adding and removing surfaces.
*solid_cavity_detect_modify_surfaces mark_id region_id add_surfs_flag
HyperMesh Tcl Modify Command
The command *solid_cavity_detect_start must be called before calling this command to generate the cavities as region entities.
- mark_id
- The ID of the mark containing the surfaces to add or remove. Valid values are 1 and 2.
- region_id
- The ID of the region containing the cavity definition to modify.
- add_surfs_flag
- 1 - The input surfaces are added to the cavity.
Examples
Add surfaces 10 and 23 to a cavity attached to region 5:
*createmark surfaces 1 10 23
*solid_cavity_detect_modify_surfaces 1 5 1
Remove surfaces 10 and 23 to a cavity attached to region 5:
*solid_cavity_detect_modify_surfaces 1 5 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
