*midsurface_switch_sides_within_plate
Switches the side of the plate to which the input surfaces belong.
*midsurface_switch_sides_within_plate mark_id reserved1 reserved2
HyperMesh Tcl Modify Command
Deletes the two components that contain copies of the model surfaces belonging to two sides of a given plate.
Switches the side number to which the surfaces on the input mark belong to the opposite side. If the selected surfaces happen to include surfaces from more than one plate, or surfaces that do not have plate information, the command will not do anything.
- mark_id
- The ID of the mark containing the input surfaces. Valid values are 1 and 2.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
To set the surfaces with IDs 5-7 to belong to the opposite of their current side, assuming the input surfaces belong to the same plate:
*createmark surfaces 1 5 6 7
*midsurface_switch_sides_within_plate 1 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
