*element1dswitch
Switches the order of 1D element nodes.
*element1dswitch mark_id
HyperMesh Tcl Modify Command
- mark_id
- The mark ID containing the 1D elements to switch.
To switch the node order of 1D elements
5-10
*createmark elems 1 5-10
*element1dswitch 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
