*exportbif
Exports the current database to Medina .bif format.
*exportbif filename
HyperMesh Tcl Modify Command
Exports the current database to Medina .bif format. Currently only nodes, elements, node sets and element sets are supported.
- filename
- The full path and file name to export to.
To export to a file named
C:/temp/test.bif:
*exportbif C:/temp/test.bifErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
