*elempatchprevaction
Moves to the previous failed element patch in the QI patch checker patch.
HyperMesh Tcl Modify Command
This command only functions between an *elempatchstartaction command and an *elempatchstopaction command.
To start the patch checker and move through several patches, changing the patch size, while
using quality criteria given from a
file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elempatchstartaction 0 1.0
*elempatchnextaction
*elempatchincraction
*elempatchdecraction
*elementqualityshutdown 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
