*hf_setdiestampingdirection
Sets the stamping direction for the die module.
*hf_setdiestampingdirection x_coord y_coord z_coord reserved
HyperMesh Tcl Modify Command
This command sets the stamping direction for the die module.
- x_coord
- x-coordinate of the vector direction.
- y_coord
- y-coordinate of the vector direction.
- z_coord
- z-coordinate of the vector direction.
- reserved
- Reserved for future use. Must be set to 0.
To set the stamping direction in the die module to (1, 0,
0):
*hf_setdiestampingdirection 1.0 0.0 0.0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
