*hiddenlinemethod Selects the algorithm used to perform hidden line removal. Syntax *hiddenlinemethod method Type HyperMesh Tcl Modify Command Description Selects the algorithm used to perform hidden line removal. Inputs method Key indicating the method of hidden line algorithm to use. 0 - Centroidal 1 - Zbuffer
