*settransparency
Toggles the shaded surface transparency feature on and off.
*settransparency onoff
HyperMesh Tcl Modify Command
- onoff
- Determines whether the shaded surface transparency feature is turned on or off.
To make the shaded surfaces in these comps on the mark
transparent:
*settransparency 1
*createmark components 1 "middle"
*transparencymark 1 Errors
None.
