*allsuppressoutput
Sets the export/do not export state of all entities.
*allsuppressoutput state
HyperMesh Tcl Modify Command
- state
- 0 - Set the state to 'export'.
Examples
To set all entities to 'export':
*allsuppressoutput 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
