*AE_UpdateLink
Updates the link for selected attachment entities.
*AE_UpdateLink mark_id uid ?pid?
HyperMesh Tcl Modify Command
Updates the link for selected attachments using a new part.
- mark_id
- The ID of the mark containing the attachments. Valid values are 1 and 2.
- uid
- The unique ID of the new part.
- pid
- The ID of the new part. Required when the part is an instance.
Examples
To update the link of attachments 101, 102, 103 using a part with UID "frame_1":
*createmark attachments 1 101 102 103
*AE_UpdateLink 1 "frame_1"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
