*edgesmarkrestore
Unsuppresses a group of edges.
*edgesmarkrestore mark
HyperMesh Tcl Modify Command
- mark
- The mark ID that contains the edges to unsuppressed.
To unsuppress edges 5, 14, 21, and
30:
*createmark lines 1 5 14 21 30
*edgesmarkrestore 1 Only face edges which are interior to a surface or shared between two surfaces may be suppressed and unsuppressed. Unsuppressing an edge can split a surface into two new surfaces, and causes it to affect the mesh. The *createmark() command is required.
