*organizecomponents
Reorganizes elements in existing components based on selected policy.
*organizecomponents policy ?preserve_element_include?
HyperMesh Tcl Modify Command
- By property
Elements of same property are grouped under one component. The component is assigned that property and the component inherits the meta data such as name, color, module, include from the property
- By material
Elements of same material are grouped under one component. The component inherits the meta data such as name, color, module, include from the material
- As one component
All valid elements are grouped under one component.
By default, the elements follow the components to the destination include which in turn follows the targeted entity (properties or materials). The current element include organization can be preserved using the optional argument preserve_element_include.
- policy
- The grouping policy. Valid values are:
- preserve_element_include
- Optional argument to preserve the current element include structure. Valid values are 0 or 1.
Examples
*organizecomponents 1*organizecomponents bypropErrors
# Handle error
}Version History
2022
