*elementqualitycollapseedge
Collapses an edge between two elements.
*elementqualitycollapseedge elem_id=<value> edge_index=<value> ?optimize=<value>?
HyperMesh Tcl Modify Command
This command collapses an edge between two elements.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_id=<value>
- The ID of the element.
- edge_index=<value>
- The index of the edge to collapse.
- optimize=<value>
- Option to optimize the node after the collapse operation is performed (default 0).
To collapse an element of ID 20 and edge index of 2 with
optimization.
*elementqualitysetup_new 2
*elementqualitycollapseedge elem_id=20 edge_index=2 optimize=1
*elementqualityshutdown 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
2023 – Updated the syntax to support name-value argument pairs and added new option optimize.
