*mechjointlimits
Sets the type of limits to use on joints for the current dummy.
*mechjointlimits limits
HyperMesh Tcl Modify Command
The mechanism must have the enabled flag set to true for this to be possible.
- limits
- 0 - Hard limits (default)
To activate soft limits on the current dummy:
*mechjointlimits 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.120
