*segmentsetreversenormals
Reverse normals of a segment set.
*segmentsetreversenormals name mark_id reverse_flag
HyperMesh Tcl Modify Command
- name
- The name of the segment set to update.
- mark_id
- The ID of the mark containing the elements to reverse when reverse_flag is 1. Valid values are 1 and 2.
- reverse_flag
- 0 - Reverse all, mark_id is ignored
Examples
Reverse normals of segment set "test" for the elements on mark
1:
*createmark elements 1 100-150
*segmentsetreversenormals "test" 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
