*setelemparamsvisualpriorities
Sets the priority for all element quality parameters when reviewing multiple criteria.
*setelemparamsvisualpriorities double_array number_of_doubles
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the priority for all element quality parameters when reviewing multiple criteria.
- double_array
- The ID of the double array containing the priority values for each quality parameter. Must always be set to 1.
- number_of_doubles
- Must currently be set to 11.
To set the priorities for all parameters:
*createdoublearray 11 3 4 7 2 1 10 8 9 0 5 6
*setelemparamvisualpriorities 1 11
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
