*attributeupdatesolverid
Updates an attribute of type solver_id.
*attributeupdatesolverid entity_type entity_id identifier solver status behavior solver_id pool_id
HyperMesh Tcl Modify Command
Solver IDs and ID pools let HyperMesh maintain the organization of models for solvers whose data model does not correspond well to the natural layout. The IDs themselves are stored on a special kind of attribute attached to the entity.
This command is used to update the solver ID attribute for a specified entity.
The need to use this command is very rare and is provided for situations that understand the ID pool organization of a particular solver.
- entity_type
- The entity type that owns the attribute.
- entity_id
- The HyperMesh internal ID of the entity.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- solver_id
- The solver ID to record to the attribute.
- pool_id
- The ID of the solver ID pool to which the solver ID belongs.
Examples
Update a solver ID attribute 1241 on a material with ID 100 to record a solver ID of 3 in
pool number
1:
*attributeupdatesolverid materials 100 1241 6 2 0 3 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
