*morphmanageedgemark
Adds a morph volume edge, subtracts a morph volume edge, or clears all morph volume edges from a morph volume edge user mark.
*morphmanageedgemark edge_id user_mark_id mode
HyperMesh Tcl Modify Command
This command allows you to add an edge, subtract an edge, or clear all edges from a specified morph volume edge user mark. Since morph volume edges are not treated as independent entities, marks containing edges can only be managed through an external command. For commands that require edge marks as input, this command must be used to place edges on the mark. The mark should be cleared before and after use to ensure proper operation.
- edge_id
- The ID of morph volume edge to add/subtract. Ignored if mode is 3.
- user_mark_id
- The ID of the user mark to operate on. Valid values are 0-3.
- mode
- 1 - Add edge to user mark
Examples
To add an edge to user mark 1:
*morphmanageedgemark 4 1 1
To clear user mark 2:
*morphmanageedgemark 0 2 3
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
