*tablecreate
Creates a new table.
*tablecreate name color config string_array number_of_columns number_of_rows
HyperMesh Tcl Modify Command
Adds a row of data to the bottom of a table.
- name
- The name of the table to create.
- color
- The color of the table. Valid values are 1-64.
- config
- Currently reserved for future use. Must be set to 1.
- string_array
- The ID of the string array that contains the data type of each column. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_columns
- Integer indicating the size (number of strings) in the string array created using *createstringarray. This must equal the number of columns in the table.
- number_of_rows
- Integer indicating the number of rows to pre-reserve in the table.
To create a table named "table1" with color 3, 4 columns of data (integer, double, string, elements), and no pre-reserved rows:
*createstringarray 4 INT DOUBLE STRING elements
*tablecreate table1 3 1 1 4 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
