*smoothelements
In the automeshing module, applies the specified smoothing operator to the mesh (if any) found on the face for the given number of times.
*smoothelements faceindex smoothmethod iterations
HyperMesh Tcl Modify Command
- faceindex
- The index of the face into the particular surface under consideration.
- smoothmethod
- The smoothing method to use.
- 0 - autodecide
- 1 - size corrected
- 2 - shape corrected
- iterations
- The number of times to apply the element smoothing operator.
To smooth the elements of the mesh of the first face of the surface twenty-five times,
using whichever algorithm the automeshing module determines is proper:
*smoothelements 0 0 25 The undo function for this command is *unsmoothelements().
None.
